[fdo-internals] Dropping off PSC
Leaf Li leaf.li at autodesk.com
Fri Nov 5 05:40:33 EDT 2010
Hi Daniel,
I can't access CVS. It returns the following error message.
connect to cvs.maptools.org:2401 failed: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Do you have any idea on it?
Thanks,
Leaf Li
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
Sent: Thursday, November 04, 2010 10:51 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Dropping off PSC
Daniel Morissette wrote:
> Leaf Li wrote:
>> By the way, do you know the address of MITAB SVN depot. I just know GDAL/OGR SVN depot contains it.
> It's a CVS repository on the maptools.org server, the CVSROOT is:
>   :pserver:dmorissette at cvs.maptools.org:/cvs/maptools/cvsroot
> and you should be able to checkout the latest source using user
> "anonymous" and an empty password.
Um... I've been too quick on the copy/paste. The CVSROOT for anonymous
access would be:
  :pserver:anonymous at cvs.maptools.org:/cvs/maptools/cvsroot
... and then "cvs login" with an empty password...
... and then "cvs checkout mitab" to get the source...
Daniel
Daniel Morissette
http://www.mapgears.com/
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
