[fdo-internals] Dropping off PSC
Daniel Morissette dmorissette at mapgears.com
Fri Nov 5 08:45:15 EDT 2010
Leaf Li wrote:
> Hi Daniel,
> I can't access CVS. It returns the following error message.
> connect to cvs.maptools.org:2401 failed: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
> Do you have any idea on it?
Do you get this when you run "cvs login"? Did you respond to the
passowrd prompt (just ENTER to return empty password). If yes then the
most likely cause would be that port 2401 would be blocked by your
firewall. Can you try from a different location with more open network
access?
Daniel Morissette
http://www.mapgears.com/
More information about the fdo-internals mailing list
