[fdo-internals] Re: FDO Build 3.6.0 - F038
Greg Boone greg.boone at autodesk.com
Fri Nov 26 09:41:27 EST 2010
I hope so... I went and modified the Autodesk FDO build process (cruise control) to spit out the FDO Open Source component distributions at the same time it build FDO for Autodesk consumption. This should work as long as the Autodesk build process continues to build FDO 3.6.0. For now it is a suitable option that will hopefully, in time, be replaced by a dedicated FDO Open Source cruise control build, external to any Autodesk build process.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, November 26, 2010 9:33 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Re: FDO Build 3.6.0 - F038
Hi Greg,
Is this regular posting of tagged builds going to be a common thing? I like
convenient access to bleeding edge stuff.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Build-3-6-0-F038-tp5777387p5777465.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
