[fdo-internals] Re: FDO Build 3.6.0 - F038
Trevor Wekel trevor_wekel at otxsystems.com
Fri Nov 26 11:34:45 EST 2010
Hi Greg and community,
I am very busy with project work at the moment and have not had much free time to contribute to the open source community.  I do have Windows and CentOS build VMs set up for MapGuide which can be used for Fdo.  If any members of the community would like to contribute to a dedicated FDO Open Source cruise control build, I can set up access to the build VMs through remote desktop on Windows and ssh on Windows.
Regards,
Trevor
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: November 26, 2010 7:41 AM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Re: FDO Build 3.6.0 - F038
I hope so... I went and modified the Autodesk FDO build process (cruise control) to spit out the FDO Open Source component distributions at the same time it build FDO for Autodesk consumption. This should work as long as the Autodesk build process continues to build FDO 3.6.0. For now it is a suitable option that will hopefully, in time, be replaced by a dedicated FDO Open Source cruise control build, external to any Autodesk build process.
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, November 26, 2010 9:33 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Re: FDO Build 3.6.0 - F038
Hi Greg,
Is this regular posting of tagged builds going to be a common thing? I like
convenient access to bleeding edge stuff.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Build-3-6-0-F038-tp5777387p5777465.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
