[fdo-internals] FDO 3.5 final release?
Trevor Wekel trevor_wekel at otxsystems.com
Tue Sep 7 11:39:56 EDT 2010
Hi Greg,
As far as I know, I can build all the binaries except for ArcSDE once we figure out the boost x64 build quirk.
For the various tar.gz files, does createtarzipbinfiles2.bat and createtarzipfiles.sh create all of them?  I did a quick check and I didn't see a "pdb" tar.gz or an "sdk" tar.gz builder in the bat files.  I expect the sdk is just a packaged up fdo install directory so I can do that one manually.
Assuming the bat/sh files create most of the .tar.gz files, I am quite happy to maintain the existing layout.
Regards,
Trevor
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: September 5, 2010 10:00 AM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] FDO 3.5 final release?
Hi Trevor,
If you look http://fdo.osgeo.org/content/fdo-350-downloads, which tar packages can you generate at this time? Are you planning to follow the existing tar file layouts or are you planning to generate a new organization of files/tar files?
Greg
Sent: Sunday, September 05, 2010 11:55 AM
On a side note, I am not sure if you are setting these environment variables, They will need to be set for a windows build.
FDO_VERSION=xxxx
PROVIDERS_VERSION=xxxx
These variables are used to set the FDO binary version information.
An example would be 6001. Where 60 is that build number (associated to the tag number) and 01 would be the first iteration of build 60.
Regards,
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Saturday, September 04, 2010 10:43 AM
Hi Greg,
Ok.  I will try the 32 bit build.  I am still getting can't open file .obj.rsp from boost when running the 64 bit build.  Here are the commands I am running on branches/3.5.
svn export svn://localsvnrepo/fdo/branches/3.5 c:\builds\fdo35x64\fdo
cd c:\builds\fdo35x64\fdo
setenvironment.bat x64
build_thirdparty.bat -p=x64 -a=buildinstall -o=c:\builds\fdo35x64\install
One modification I did make to setenvironment.bat was to update the Visual Studio path
SET ACTIVEPATHCHECK="C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC"
Regards,
Trevor
Sent: September 3, 2010 3:52 PM
Hi Trevor,
I tried building boost Win32 on a Win64 OS using the Visual Studio x86 compiler tools and I didn't encounter any issues.
Greg
Sent: Tuesday, August 31, 2010 12:55 AM
Hi Greg,
I am able to build the following:
Windows: MySQL, ODBC, PostgreSQL, GDAL, KingOracle, OGR, PostGIS, SDF, SHP, SQLite, WFS, WMS
Linux: MySQL, ODBC, PostgreSQL*, GDAL, KingOracle, OGR, PostGIS*, SDF, SHP, SQLite, WFS, WMS
*For Linux, I may have build issues with PostgreSQL and PostGIS related to the Thirdparty pgsql libs.  I get a number of unresolved externals for both providers and need to investigate further.
Regards,
Trevor
Sent: August 30, 2010 10:07 PM
Trevor,
What builds (minus ArcSDE) are you capable of posting? Why don't we focus on posting what you can build right now.
I can work on posting the ArcSDE libraries once you have posted the main build. I can also look to see if I can reproduce the boost x86 issue so you can perform the win32 build on your win64 machine.
As for testing, I propose we post and have the community validate.
Greg
Sent: Monday, August 30, 2010 11:34 PM
So a number of submissions have been made lately. Are there any objections to having these included in a new candidate build?
Sent: Saturday, August 28, 2010 12:35 PM
Hi Jackie,
Your question is timely.  I have been discussing the FDO builds offline with Greg and others over the past few months.  Since MapGuide needs FDO for Windows and Linux, I thought it was reasonable for me to do the FDO builds as well.  I believe there are a few things we need to address:
1.  Build OS for Windows
Currently, the FDO 3.5 builds are cleaner on a 32 bit OS.  From what I recall, one of the third party dependencies (boost?) is a bit out of date and gets a little cranky with the (x86) in the path name.  I believe this has been resolved in FDO trunk.  The 32/64  bit OS wouldn't normally matter but I was foolish enough to install a 64 bit OS on the MapGuide build machine.
We have a couple of options available to resolve this:
a.  Set up a separate build VM for FDO with a 32 bit OS.
b.  Update the third party libs and compile using the existing MapGuide 64 bit build VM.
Option a. is cleaner and I think it would be better if FDO had its own build machine.  I suppose I can eat the licensing cost (bummer).
2. ArcSDE Providers
I do not have access to ESRI SDKs so I cannot build the ESRI FDO Providers.  If someone else in the community would be willing to build the ESRI Providers, that would be great.
3. Resourcing
To be honest, I am very busy right now and would welcome a collaborator on the FDO builds.  The build infrastructure is web accessible and I would be more than willing to give access to anyone able to help out with the FDO builds.
4. Build Validation
I am competent in FDO but not an FDO expert.  And with 10(+?) providers to test, build validation is a major undertaking.  We should open up a discussion on appropriate build validation steps.  Builds are fine.  Builds that work are better.
Regards,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: August 28, 2010 2:45 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] FDO 3.5 final release?
Hi All,
Is there any word/plans on a final FDO 3.5 release? The download site only has the RC1 release and that itself is several months old now.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-3-5-final-release-tp5472205p5472205.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
