[fdo-internals] RE: FDO RFC 57 is revised, can you review it.
Greg Boone greg.boone at autodesk.com
Fri Apr 1 23:28:54 EDT 2011
Hi Cheney,
In the RFC, can you revisit the example and expand it to demonstrate how a caller would request an initial FdoISelect area(s) with height/width and how an area/resolution would then be reselected/altered by passing values into the GetFeatureInfo command? I think readers needs to see the linkage between an initial set of FdoISelect statements returning tiles of information and the subsequent calls to GetFeatureInfo.
Regards,
Greg
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Cheney Sun
Sent: Friday, April 01, 2011 2:52 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] FDO RFC 57 is revised, can you review it.
Hi all,
I revised the FDO RFC 57 to fix some potential usage issues. Can you review it?
http://trac.osgeo.org/fdo/wiki/FDORfc57
Thanks,
Cheney
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20110402/2d9021bc/attachment.html
More information about the fdo-internals mailing list
