[fdo-internals] RE: GVC_TRACE_FILE and GenericRdbms
Brent Robinson brent.robinson at autodesk.com
Tue Aug 2 13:17:28 EDT 2011
Hi Trevor,
GVC_TRACE_FILE is only supported by the Autodesk Oracle provider. However, there is also an FDO_TRACE_FILE environment variable that behaves the same way. It's supported by all of the other GenericRdbms providers.
Brent.
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Tuesday, August 02, 2011 12:59 PM
To: FDO Internals Mail List
Subject: [fdo-internals] GVC_TRACE_FILE and GenericRdbms
Hello list,
Which providers support the GVC_TRACE_FILE logging mechanism?  Some of the unit tests under Providers\GenericRdbms\Src\UnitTest\Common seem to indicate that GVC_TRACE may be supported as part of the generic RDBMS infrastructure (Microsoft SQL Server Spatial, ODBC, PostGIS, MySQL, and Autodesk Oracle Provider).
Thanks,
Trevor
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20110802/bb7230d4/attachment.html
More information about the fdo-internals mailing list
