[fdo-internals] Re: insert error control properties with KingOracle
mdelsinne mdelsinne at gmail.com
Fri Dec 2 08:14:42 EST 2011
I run IApplySchema command before every insert command because IApplySchema
create the table in Oracle.
And if I do not apply the schema, I can not set the insert command
setfeatureclassname.
Thank's
View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7054641.html
Sent from the FDO Internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
