[fdo-internals] Re: insert error control properties with KingOracle
Zac Spitzer zac.spitzer at gmail.com
Fri Dec 2 10:21:24 EST 2011
that naming convention is not 100% guaranteed according to Harris,
but you can, in my experience rely on it
FDO class naming so needs to be addressed, but I have given up
after too much well, ummm (see the mailing list archives) sigh
On Sat, Dec 3, 2011 at 1:07 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Would you run a CREATE TABLE or ALTER TABLE everytime you do a SQL INSERT
> statement? Of course not!
> IApplySchema is equivalent to doing a such CREATE/ALTER TABLE and doing it
> before insert is completely not necessary.
> You know what table you want to insert into, the King Oracle provider just
> has a wacky naming convention for feature classes on a default Oracle
> Schema, which is:
> [Schema Name]~[Table Name]~[Geometry Column]
> That is what you use for SetFeatureClassName()
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/insert-error-control-properties-with-KingOracle-tp7046704p7054826.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fdo-internals mailing list
