[fdo-internals] RE: SQL Server Spatial database permissions
Martin Morrison martin.morrison at edsi.com
Wed Mar 30 15:33:36 EDT 2011
Not that I am aware of.  Keep in mind you won't be creating temp tables etc through FDO.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Wednesday, March 30, 2011 3:32 PM
To: FDO Internals Mail List
Subject: [fdo-internals] RE: SQL Server Spatial database permissions
Thanks Martin,
I was also wondering if there were any permissions needed for system tables?
Regards,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: March 30, 2011 10:59 AM
Read only -> Connect, Select
Write -> Connect, Select, Insert, Update, Delete
Martin Morrison
Roanoke, VA  24018
540.345.1410
gis.edsi.com
Sent: Wednesday, March 30, 2011 12:37 PM
Subject: [fdo-internals] SQL Server Spatial database permissions
Hello,
Is there documentation available for the database permissions required to successfully use the SQL Server Spatial Provider on both FDO-enabled data stores and non-enabled data stores?
Regards,
Trevor
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
