[fdo-internals] Patch for ticket 493 (GDAL provider doesn't return spatial contexts)
Greg Boone greg.boone at autodesk.com
Thu May 12 09:42:28 EDT 2011
Hi Jackie,
The code looks good. However, you will need to update the unit test project's makefile.am to add references to the new test files.
Do you have commit rights? If so, go ahead and submit.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, May 11, 2011 12:04 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Patch for ticket 493 (GDAL provider doesn't return spatial contexts)
Hi All,
I have attached a patch for the GDAL provider that fixes default extents being returned for rasters that have no associated coordinate system
http://trac.osgeo.org/fdo/ticket/493
This patch was made against the current FDO 3.5 branch. Given the lack of real changes in the actual provider for a while, this patch should be easily appliable to 3.6 branch and trunk.
Only tested for windows given my lack of experience with the gcc/autotools stack. Structurally speaking, there only 2 new files for the unittest project which is a new unit test to verify that spatial context queries on a small set of known GDAL test rasters with no coordinate system information will return the correct extents (ie. The same extents if you were to query the raster via the gdalinfo utility)
Please review. Thanks.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Patch-for-ticket-493-GDAL-provider-doesn-t-return-spatial-contexts-tp6352463p6352463.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
