[fdo-internals] read a FeatureClass
Romica Dascalescu Romica.Dascalescu at autodesk.com
Thu Nov 3 10:13:14 EDT 2011
Get class names  (FdoCommandType_GetClassNames) is not supported by SDF in FDO 3.6, is only implemented in FDO 3.7
You still can use describe schema  (FdoCommandType_DescribeSchema) and get the whole schema, look for your class in the schema.
To delete a feature you need to create a delete command (FdoCommandType_Delete).
You can find more how to do it in the unit tests (https://svn.osgeo.org/fdo/trunk/Providers/SDF/Src/UnitTest)
Regards,
Romica
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of mdelsinne
Sent: Thursday, November 03, 2011 10:07 AM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] read a FeatureClass
Hello, I would like to recover the features class name of a sdf file. I need to have the name of the feature class and then do a delete feature.
I tried using the command "GetClassName" but he replied that the command is not supported by the provider ("OSGeo.SDF.3.6"), I do not see how? Have you any idea?
thank you
View this message in context: http://osgeo-org.1803224.n2.nabble.com/read-a-FeatureClass-tp6959138p6959138.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
