[fdo-internals] RE: Create a branch for GDAL 1.9 upgrade
Greg Boone greg.boone at autodesk.com
Wed Jan 25 11:14:35 EST 2012
A question.... Will GDAL 1.8 be binary compatible with 1.9? If customers are using a build of the WMS provider or GDAL provider that was linked to 1.8, can they swap in the GDAL 1.9 version of the DLL?
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Tuesday, January 24, 2012 8:24 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] RE: Create a branch for GDAL 1.9 upgrade
Hi Greg,
It is mostly GDAL build files for now.  Some of the unit test projects (WMS, GDAL) have to be updated to copy gdal19.dll instead of gdal17.dll.  I was mistaken with the WFS provider - it does not use GDAL so no problems there.  OGR does use GDAL and doesn't have a unit test so I am not expecting any changes to OGR.
Here's the changed file list so far:
Thirdparty/gdal
- Entire directory replaced with source for GDAL 1.9 release
Providers/GDAL/Src/UnitTest/UnitTest.vcxproj
Providers/WMS/Src/UnitTest/UnitTest.vcxproj
Thirdparty/Build.bat
- change gdal17 to gdal19
Thirdparty/gdal/gdal.vcxproj
Thirdparty/gdal/gdal_vs10.sln
Thirdparty/gdal/nmake.opt
- Updates for GDAL 1.9 source tree and FDO build structure
There will be some minor install image changes due to the change from gdal17 to gdal19.  I expect the same on Linux (when I get that far).
Regards,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: January 24, 2012 6:13 PM
Yes, the VC 2008 builds are intended to work.
Will only GDAL build files be affected? If others, what changes are you proposing?
What changes are you proposing for the WMS/WFS providers?
Greg
Sent: Tuesday, January 24, 2012 7:57 PM
Hi list,
I am making good progress on the GDAL 1.9 upgrade.  Windows/VC10 is getting close to complete.  I haven't started Linux yet.  So far, no changes to .cpp/.h files - just changes to various "build files".
The unit tests for the GDAL provider are executing cleanly on 32 and 64 bit.  I still need to do some minor fixups for the WMS and WFS providers and some functional validation of the new GDAL Provider with MapGuide.
Since we are releasing FDO 3.7 using VC10, do we still need to maintain the VC9 (2008) builds?
Regards,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: January 5, 2012 12:15 PM
Subject: Re: [fdo-internals] RE: Create a branch for GDAL 1.9 upgrade
On Thu, Jan 5, 2012 at 10:34 AM, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Do you know if ECW, MrSID, JPEG 2000 and Oracle Geo Raster are being
> worked on for Linux?  The Enterprise Linux GIS link wasn't too
> promising
> http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS#Formats_supported_by_G
> DAL
Trevor,
I know that there are folks who are successfully building and using ECW, MrSID, JPEG2000 and Oracle GeoRaster support on Linux.  But to the best of my knowledge this is being done individual by individual rather than building sharable plugins.
Partly this is because of
the variety of Linux versions and partly it is an issue with licensing constraints on most of the above.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com light and sound - activate the windows | http://pobox.com/~warmerdam and watch the world go round - Rush    | Geospatial Software Developer _______________________________________________
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
