[fdo-internals] FDO RFC 63 In-memory Spatial Index - for review
Haris Kurtagic haris at sl-king.com
Thu Jun 28 07:30:10 PDT 2012
+1
Haris
On Thu, Jun 28, 2012 at 4:22 PM, Greg Boone <greg.boone at autodesk.com> wrote:
> Voting will close end of day.
> Greg
> From: fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
> Sent: Monday, June 25, 2012 4:22 PM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] FDO RFC 63 In-memory Spatial Index - for review
> If Gavin has no further concerns, the voting can resume.
> +1
> Greg
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
> Sent: Monday, June 25, 2012 3:39 PM
> Hi,
> I have addressed Gavin's concerns 10 days ago. Any other concerns so voting
> can resume?
> Thanks,
> Dan.
> From: Dan Stoica
> Sent: Thursday, June 14, 2012 3:37 PM
> Subject: RE: [fdo-internals] FDO RFC 63 In-memory Spatial Index - for review
> Please see inline.
> Thanks,
> Dan.
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Gavin Cramer
> Sent: Thursday, June 14, 2012 12:54 PM
> I do have more comments, but just have not gotten to reply previously.
> 1.       Can there be a way to get segment information (at least for line
> segments) out of the results without having to implement a segment visitor?
> At least for callers who need XY information (the main mode of operation for
> spatial filtering), it only requires two more binary digits (two Boolean
> values) to encode ordinate order, mapping extents (four doubles in a fixed
> order) back to the original XY ordinates.  Example, one Boolean indicates
> whether Min X represents the first X ordinate of the original line segment,
> and the other Boolean indicates whether the Min Y represents the first Y
> ordinate of the original line segment.
> In order to retrieve the original XY ordinates they have to be stored into
> the R-tree. The two booleans are not enough. Regardless, a segment visitor
> is very fast and in my opinion this extra memory consumption is not
> justified.
> 2.       The Marker encoding for sub-part and segment index is easy to
> overflow in Mode 3.  A larger result needs to be available, or at least a
> return value to indicate an overflow.  Both can be done, so that the caller
> can just call a different method to get the larger result when needed.
> The RFC states the following:
> /// In Mode #3 a exception will be thrown in case the encoding fails. In
> this case Mode #2 can be used instead.
> 3.       Marker sorting should be supported, especially if #1 above is not
> supported.  It’s just as useful to callers as the DecodeMarker method.
> Not sure marker sorting  fits too well into this RFC. It’s trivial for the
> client to collect the markers in a standard vector and then call sort().
> Gavin
> Sent: Thursday, June 14, 2012 12:34 PM
> If there are no comments, I would like to request a vote on this RFC.
> +1
> Greg
> Sent: Monday, June 04, 2012 11:42 AM
> Subject: [fdo-internals] FDO RFC 63 In-memory Spatial Index - for review
> Hi,
> Please review the proposal for an in-memory Spatial Index.
> http://trac.osgeo.org/fdo/wiki/FDORfc63
> Thanks in advance for your feedback,
> Dan.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
