[fdo-internals] RFC 65 Implement Resampling for GDAL Provider
Haris Kurtagic haris at sl-king.com
Tue Oct 23 15:02:54 PDT 2012
+1
Haris
On Wed, Oct 24, 2012 at 12:00 AM, Greg Boone <greg.boone at autodesk.com> wrote:
> Well, +1 again.
> Voting has been open for some time now. Final votes are due tomorrow, by 5pm
> ET.
> Greg
> From: fdo-internals-bounces at lists.osgeo.org
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
> Sent: Tuesday, October 23, 2012 5:54 PM
> To: FDO Internals Mail List
> Subject: Re: [fdo-internals] RFC 65 Implement Resampling for GDAL Provider
> Ok.  Thanks Greg.  I make a couple of small updates to the RFC and attached
> the latest code yesterday.
> Regards,
> Trevor
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
> Sent: October 23, 2012 3:52 PM
> I think the RFC is ok, the final say on the code review is Frank.
> Greg
> Sent: Sunday, October 21, 2012 10:56 PM
> Hi Frank,
> I have attached an updated patch to RFC 65 with the CPLPrintPointer
> modification and compile fixes [Makefile.am updates] for Linux.  The code
> compiles and the FDO unit tests are clean on VC10 32bit Windows, VC10 64bit
> Windows, and 32bit CentOS 5.
> I was also able to verify the functionality visually in MapGuide on all
> three platforms.  No code changes are required for MapGuide.  Just add the
> following parameter to the feature source XML document:
> <Parameter>
>     <Name>ResamplingMethod</Name>
>     <Value>bilinear</Value>
> </Parameter>
> If everyone is ok with the RFC “as is”, can we get it approved?  I can check
> the code in the next day or so.
> Regards,
> Trevor
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
> Sent: October 12, 2012 5:30 PM
> On Fri, Oct 12, 2012 at 3:20 PM, Trevor Wekel <trevor_wekel at otxsystems.com>
> wrote:
> Hi Frank,
> I was not aware of VRTWarpedDataset so did not consider it initially.
> So I took a quick look at vrtwarped.cpp.  I have a question.  In
> vrtwarped.cpp, the ProcessBlock() seems to cache the results of the warp
> operation (GDALCopyWords around line 1174) into each raster band.  Does this
> mean that all blocks will end up being cached?
> Trevor,
> Yes, VRTWarpedDataset will always push produced tiles into the GDAL block
> cache.  Note that most drivers go through the block cache too.
> For FDO, we basically call a ReadNext() to suck the contents of the tile
> into a buffer supplied by the caller.  The ReadNext() drives the calls to
> _getTile().  As far as I can tell, our access pattern is linear and we only
> access each tile once.  If we switch to using VRTWarpedDataset, will we have
> to call ProcessBlock() for each tile?  Will this end up caching all the
> blocks as we do the linear read?
>  In a web context, the ideal would be a long lived server which keeps around
> the VRTWarpedDataset for subsequent use.  I not sure how practical that is
> in the FDO/MapGuide use case.   In this situation caching the blocks can
> help subsequent views but there might be better other layers at which to do
> that.
> As an alternative to using VRTWarpedDataset, would it be ok to instantiate a
> GDALWarpOperation as a member of the FdoRfpStreamReaderByTileResample?
> Pseudo code would be something like this:
> FdoRfpStreamReaderGdalByTileResample::FdoRfpStreamReaderGdalByTileResample()
> m_warpOp = new GDALWarpOperation();
> FdoRfpStreamReaderGdalByTileResample::_getTile()
> warpOptions = GDALCreateWarpOptions();
> // populate warp options
> m_warpOp->Initialize(warpOptions);
> m_warpOp->WarpRegion(0,0,origXSize,origYSize);
> This may improve the speed of the _getTile() call if a) Initialize() can be
> called more than once and b) the new GDALWarpOperation() does a lot of setup
> work
> It is more likely to be the Iniitalize() that is expensive and reinitialzing
> an existing WarpOperation is not a well trod path and likely to lead to
> pain.  I advise against it.  In retrospect, sticking with your existing
> approach is likely ok but you might want to get a sense of how much time is
> spent in the setup code vs. the actual warping.   Larger tiles will help.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
