[fdo-internals] How to get the four corners from a (raster data type) Feature
Alfredo Muela-Romero alfredo.muela at pds.nl
Wed Apr 10 03:20:09 PDT 2013
Hi everyone,
Given a Feature class (in particular a raster data one, although I guess it
can be generalized), I am trying to figure out the four corners (assuming
same "z"-dimension).
The approach is to execute a SQL command to retrieve MINX, MINY, MIZ, MAXX,
MAXY, MAXZ from SDE.LAYERS with the appropriate owner and table. From those
two coordinates that the z-dimension equality can be checked and the 4
corners defined.
With that approach I get the expected values... usually. In other words,
there are some features when the values from the query are hugely
different. In order to validate the results, I use ArcCatalog to compare
the Top, Left, Right and Bottom values from the Extent property.
My questions are:
  - can anyone shed some light on why is that happening?
  - should I use a different approach to get this information?
Many thanks,
Alfredo.
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20130410/8ee5ed91/attachment.html>
More information about the fdo-internals mailing list
