[fdo-internals] Patch for ticket 864: BUG in SQL Server Spatial FDO provider when using filter
Andy Zhang Andy.Zhang at autodesk.com
Mon Aug 12 17:40:27 PDT 2013
Hi Jackie,
It is a general issue of almost all RDBMS. It should be caused by the fix for ticket #802 http://trac.osgeo.org/fdo/ticket/802.
Could you please check if this patch also works for #802?
Thanks
Andy
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, August 12, 2013 4:18 PM
To: fdo-internals at lists.osgeo.org
Subject: [fdo-internals] Patch for ticket 864: BUG in SQL Server Spatial FDO provider when using filter
Hi All,
I've attached a patch for ticket 864 (BUG in SQL Server Spatial FDO provider when using filter)
http://trac.osgeo.org/fdo/ticket/864
The patch tweaks the FDO filter analysis to always parenthesise the top-level operands if the top-level operator is a logical AND which is needed if the FDO attribute has a series of chained logical OR conditions like the example filter in the ticket.
Please review. Thanks.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Patch-for-ticket-864-BUG-in-SQL-Server-Spatial-FDO-provider-when-using-filter-tp5072004.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
