[fdo-internals] Unit Test suite instability
Greg Boone greg.boone at autodesk.com
Thu Mar 13 09:03:20 PDT 2014
>> I gather these files still existed on your end which is why the SHP tests are OK. But as it stands, the SHP test suite will fail for anyone who does not know about this change that was made 6 years ago.
These tests should be #ifdef'ed out.
Greg
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, March 13, 2014 8:50 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] Unit Test suite instability
My notes about the SHP test failures were correct (on Windows at least)
There were a bunch of test SHP files removed by this revision 6 years ago:
http://trac.osgeo.org/fdo/changeset/3738
These test SHP files were still being referenced in the SHP provider test suite which caused the CppUnit failures I listed on that spreadsheet.
I restored these SHP files to their expected location (I basically checked out a pre-r3738 copy of the test data) and the SHP provider test suite passes on Windows for 32-bit and 64-bit.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Unit-Test-suite-instability-tp5128256p5128776.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
