[fdo-internals] FDO version number and branches
Karsten Winter karsten.winter at autodesk.com
Thu Dec 17 07:49:20 PST 2015
Hi all
The VS 2015 porting is now finished and integrated into trunk.
The next step would be to update the version in trunk to 4.1.0.0. I have planned this for the first week of January, any concerns regarding this?
The next step after the version number would be to think about the branching of trunk. Any plans/ideas when this can be done?
Are there any open tasks in the open source part, which have to be included in the 4.1 version?
Best regards
Karsten
Karsten Winter
Software - Engineer
Solution Engineering, IPG- ICP
Autodesk S.a.r.l.
Worbstrasse 223
3073 Gümligen
Switzerland
Central   +41 (0)31 9582020
Fax         +41 (0)31 9582022
[Description: Description: Description: Description: Description: Description: cid:C3593B93-B89C-44B0-A763-6E009A4C92D6]
CONFIDENTIALITY NOTICE
This email transmission is intended only for the use of the individual or entity named above and may contain information that is confidential, privileged and exempt from disclosure under applicable law. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or use of any of the information contained in this transmission is strictly PROHIBITED
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20151217/80884c1b/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20151217/80884c1b/attachment.png>
More information about the fdo-internals mailing list
