[fdo-internals] Installer projects with
Karsten Winter karsten.winter at autodesk.com
Mon Nov 9 05:54:34 PST 2015
Hi all
We have 2 open source projects for an installer, which still use the VS 2010 c++ compiler.
I reference to ..\Fdo\Install\ XsdInstallPaths \XsdInstallPaths.vcxproj and ..\Fdo\Install\ XsdPrep \XsdPrep.vcxproj
Who needs those projects in the open source community and has anyone a problem that we convert them to VS 2015 c++ compiler with all the other projects?
Best regards
Karsten
Karsten Winter
Software - Engineer
Solution Engineering, IPG- ICP
Autodesk S.a.r.l.
Worbstrasse 223
3073 Gümligen
Switzerland
Central   +41 (0)31 9582020
Fax         +41 (0)31 9582022
[Description: Description: Description: Description: Description: Description: cid:C3593B93-B89C-44B0-A763-6E009A4C92D6]
CONFIDENTIALITY NOTICE
This email transmission is intended only for the use of the individual or entity named above and may contain information that is confidential, privileged and exempt from disclosure under applicable law. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or use of any of the information contained in this transmission is strictly PROHIBITED
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20151109/af6cc300/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20151109/af6cc300/attachment.png>
More information about the fdo-internals mailing list
