[fdo-internals] new GDAL version
Karsten Winter karsten.winter at autodesk.com
Wed Oct 14 08:51:54 PDT 2015
Hi all
I will move the GDAL 2.0.1 update to a later time, when I have finished the VS2015 migration.
The new version has a lot of API changes which corrupts the OGR build.
So I will first finish the VS2015 migration (with the workaround of GDAL) and then include GDAL 2.0.1 in trunk as separate step.
Best regards
Karsten
-----Original Message-----
From: fdo-internals [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Karsten Winter
Sent: Wednesday, October 14, 2015 3:56 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] new GDAL version
You are right.
I have seen that the file will be named automatically (gdal200.dll).
Best regards
Karsten
From: fdo-internals [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Johan Van de Wauw
Sent: Wednesday, October 14, 2015 1:25 PM
This version number is normally embedded in the build.
https://github.com/OSGeo/gdal/blob/trunk/gdal/nmake.opt#L189
Kind Regards,
Johan
On Wed, Oct 14, 2015 at 1:00 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> "110" reflects the version of GDAL (1.10) used to build it.
> I think it would be safe to assume the same naming convention.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/new-GDAL-version-tp5230032p5230037
> .html Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
