[fdo-trac] #101: Please alter 3.2.x GDAL gtiff makefile flags
FDO trac_fdo at osgeo.org
Wed Aug 1 10:17:00 EDT 2007
 Reporter:  jbirch                 |         Owner:  gregboone
     Type:  defect                 |        Status:  closed
 Priority:  major                  |     Milestone:
Component:  Thirdparty Components  |       Version:  3.2.2
 Severity:  3                      |    Resolution:  fixed
 Keywords:                         |   External_id:
Changes (by warmerdam):
  * status:  assigned => closed
 * cc: warmerdam (added)
  * resolution:  => fixed
  * milestone:  3.2.2 =>
Comment:
 I have applied this patch in:
 fdocore/branches/3.2.x/Thirdparty/GDAL1.3/src/frmts/gtiff/libgeotiff/makefile.vc
 Note, this change causes the libgeotiff API to be exported from the DLL
 which is necessary to build some GDAL raster drivers as plugins.
 I have removed the 3.2.2 milestone since to the best of my knowledge that
 is past.  If there is a 3.2.3 this would appear in it, otherwise folks
 will have to draw from the 3.2.x branch.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/101#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
