[fdo-trac] #103: Add x64 Configurations to the FDO API and SDF Provider Windows Build Scripts
FDO trac_fdo at osgeo.org
Wed Aug 15 15:07:37 EDT 2007
Scripts
 Reporter:  gregboone        |         Owner:  gregboone
     Type:  enhancement      |        Status:  new
 Priority:  minor            |     Milestone:  3.3.0
Component:  FDO API          |       Version:  3.3.0
 Severity:  2                |    Resolution:
 Keywords:  Win64;x64;Build  |   External_id:
Old description:
> This submission will add Win64 support to the OSGeo FDO API and the OSGeo
> SDF
> Provider. A new platform configuration 'x64' has been added to all
> relevant
> windows project and solution files. Developers can now either choose to
> build the
> standard 'Win32' Debug and Release configurations or the 'x64' Debug and
> release
> configurations.
> In the process of adding the 'x64' configurations, several project files
> were
> cleaned up to remove stale configurations that were no longer being
> maintained
> or used. The general goal is to have only a Debug and a Release
> configuration
> for each platform supported.
> As a part of the x64 changes, several source files were changed to fix
> warnings
> or resolve build issues. Many of these changes happened in the Third-
> party
> directory. If updates are to be made to projects in the Third-party from
> the
> original posted source on the originating sites, care should be made to
> preserve
> the x64 changes.
> In addition of the project file and source file changes, the Open Source
> build
> scripts were also updated to allow the x64 configurations to be built
> through a
> command line process. If an x64 configuration is needed, use the -p
> option to
> specify the platform that needs to be built.
> Here are the parameters to the new build.bat script.
> build.bat [-h]
>           [-o=OutFolder]
>           [-c=BuildType]
>           [-p=PlatformType]
>           [-a=Action]
>           [-w=WithModule]
>           [-d=BuildDocs]
>           [-py=BuildPythonWrappers]
> Help:                  -h[elp]
> OutFolder:             -o[utpath]=destination folder for binaries
> BuildType:             -c[onfig]=release(default), debug
> PlatformType:          -p[latform]=win32(default), x64
> Action:                -a[ction]=build(default),
>                                  buildinstall,
>                                  install,
>                                  clean
> BuildDocs:             -d[ocs]=skip(default), build
> BuildPythonWrappers:   -py[thon]=skip(default), build
> WithModule:            -w[ith]=all(default),
>                                fdo,
>                                providers,
>                                shp,
>                                sdf,
>                                wfs,
>                                wms,
>                                arcsde,
>                                odbc,
>                                mysql,
>                                gdal
> * NOTE that there are still a few outstanding issues with the x64 builds
> 1) The build scripts cannot resolve the INCLUDE path settings hen using
> the amd64 compiler
> 2) The stampver scripts are not recognizing that the 64bit binaries have
> resources attached to them. Therefore, stamping the 64bit binaries has
> been temporarily disabled.
New description:
 SDF Provider. A new platform configuration 'x64' has been added to all
 relevant windows project and solution files. Developers can now either
 choose to build the standard 'Win32' Debug and Release configurations or
 the 'x64' Debug and release
 configurations.
 were cleaned up to remove stale configurations that were no longer being
 maintained or used. The general goal is to have only a Debug and a Release
 configuration for each platform supported.
 warnings or resolve build issues. Many of these changes happened in the
 Third-party directory. If updates are to be made to projects in the Third-
 party from the original posted source on the originating sites, care
 should be made to preserve the x64 changes.
 build scripts were also updated to allow the x64 configurations to be
 built through a command line process. If an x64 configuration is needed,
 use the -p option to specify the platform that needs to be built.
 build.bat
           [-h][[BR]]
           [-o=!OutFolder][[BR]]
           [-c=!BuildType][[BR]]
           [-p=!PlatformType][[BR]]
           [-a=Action][[BR]]
           [-w=!WithModule][[BR]]
           [-d=!BuildDocs][[BR]]
           [-py=!BuildPythonWrappers][[BR]]
 Help:                  -h[elp][[BR]]
 !OutFolder:             -o[utpath]=destination folder for binaries[[BR]]
 !BuildType:             -c[onfig]=release(default), debug[[BR]]
 !PlatformType:          -p[latform]=win32(default), x64[[BR]]
 Action:                -a[ction]=
                                  build(default),
                                  buildinstall,[[BR]]
                                  install,[[BR]]
                                  clean[[BR]]
 !BuildDocs:             -d[ocs]=skip(default), build[[BR]]
 !BuildPythonWrappers:   -py[thon]=skip(default), build[[BR]]
 !WithModule:            -w[ith]=
                                all(default),
                                fdo, [[BR]]
                                providers, [[BR]]
                                shp, [[BR]]
                                sdf, [[BR]]
                                wfs, [[BR]]
                                wms, [[BR]]
                                arcsde, [[BR]]
                                odbc, [[BR]]
                                mysql, [[BR]]
                                gdal[[BR]]
 the amd64 compiler
Ticket URL: <http://trac.osgeo.org/fdo/ticket/103#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
