[fdo-trac] #104: PostGIS provider cannot insert features with geometry
FDO trac_fdo at osgeo.org
Tue Aug 28 22:08:39 EDT 2007
 Reporter:  cwilbur           |         Owner:  mloskot
     Type:  defect            |        Status:  assigned
 Priority:  major             |     Milestone:  3.3.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  3                 |    Resolution:
 Keywords:                    |   External_id:
Comment (by mloskot):
 Chuck, you're right about incomplete handling of 3 and 4 dims. I applied
 some fixes realated to this issue (r3240, see also ticket #108) but there
 is still problem in ''ExpressionProcessor'' class, where geometry is
 dumped to WKB using ''FdoFgfGeometryFactory::GetWKB()'' insead to EWKB
 with custom writer.
 My suggestion is to still keep moving toward 3 and 4 dim support and using
 EWKB internally. I will continue my work and add EWKB writing support.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/104#comment:15>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
