[fdo-trac] #81: ArcSDE 91 and 9.2 not recognizing nvarchar2 datatype
FDO trac_fdo at osgeo.org
Fri Jun 1 01:39:05 EDT 2007
   Reporter:  kidsmake6 at msn.com  |       Owner:  gregboone
       Type:  defect             |      Status:  new
   Priority:  blocker            |   Milestone:  3.3.0
  Component:  ArcSDE Provider    |     Version:  3.2.2
   Severity:  3                  |    Keywords:
External_id:                     |
 When I add a new field to my oracle 10gr2 database. It uses the nvarchar2
 datatype. If I connect to that database with FDO 3.2.2 beta I see all
 filed with the exception of the text fileds defined with nvachar2. If I
 create a new field and specify varchar2 I can then view the data
 correctly.
 Please add support for nvarchar2. If I am not mistaken it would be needed
 by any database that requires internationalization character
 support(utf-8).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/81>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
