[fdo-trac] #5: GDAL: Update FDO Thirdparty to latest GDAL Source
FDO trac_fdo at osgeo.org
Wed Mar 7 11:20:29 EST 2007
 Reporter:  gregboone              |         Owner:  gregboone
     Type:  enhancement            |        Status:  assigned
 Priority:  minor                  |     Milestone:  3.3.0
Component:  Thirdparty Components  |       Version:  3.3.0
 Severity:  2                      |    Resolution:
 Keywords:  GDAL WMS               |   External_id:
Comment (by gregboone):
 I see your point about the install and am willing to change it.
 However, I am unclear what you mean by gdal-config. Can you elaborate on
 your proposed plan?
 The gdal files can be installed into /usr/local/fdo3.3.0 using the gdal
 configure script and seting the prefix parameter to the fdo install
 directory. A side effect of installing into /usr/local/fdo-3.3.0 would be
 that the gdal header files would be installed into the fdo include
 directory. Is this a recommended approach?
Ticket URL: <http://trac.osgeo.org/fdo/ticket/5#comment:13>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
