[fdo-trac] #43: SHP, SDF: wrong results when quering multi polygons
FDO trac_fdo at osgeo.org
Fri Mar 16 16:25:16 EDT 2007
   Reporter:  danstoica     |       Owner:  danstoica
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.3.0
  Component:  SHP Provider  |     Version:  3.2.0
   Severity:  3             |    Keywords:
External_id:                |
 A decision was previosly made to not alter the polygon returned from a shp
 file.
 As a result when reading, SHP provider never returns a MultiPolygon. They
 are
 all Polygons.
 In consequence, when doing spatial queries on a Polygon (which is in fact
 a
 multipolygon) and the selected area in not inside the external ring or
 touching
 the ring's boundary, nothing will be returned.
 The solution was fix the spatial query (not the reading). That is, before
 passing the geometry to the spatial filter, the Polygon needs to be
 checked and
 see "Is this polygon actually a multipolygon?" If so, create a
 multipolygon and
 pass it down to the spatial filter instead.
 The same applies to the SDF provider.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/43>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
