[fdo-trac] #67: RDBMS: Using unsupported buffer type: 0 (parameter: 1)
FDO trac_fdo at osgeo.org
Wed May 2 08:55:31 EDT 2007
   Reporter:  kgrootendorst at baird.com  |       Owner:  gregboone
       Type:  defect                   |      Status:  new
   Priority:  major                    |   Milestone:  3.3.0
  Component:  FDO API                  |     Version:  3.2.0
   Severity:  3                        |    Keywords:
External_id:                           |
 Using MGOS 1.1, MySQL 5.0.22, FDO 3.2.  When configuring a feature
 resource using Studio (trial version), using provider OSGeo.MySQL, testing
 connection to database yields the error "An exception occurred in FDO
 component. RDBMS: Using unsupported buffer type: 0  (parameter: 1)".
 Below is from the server log:
 Error: An exception occurred in FDO component.  RDBMS: Using unsupported
  StackTrace:
   - MgFeatureServiceHandler.ProcessOperation line 83 file
 c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
   - MgOpTestFeatureSourceConnection.Execute line 103 file
 c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
   - MgFdoConnectionManager.Open line 815 file
 c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\common\manager\FdoConnectionManager.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/67>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
