[fdo-trac] #75: Doubled code in sample from devguide
FDO trac_fdo at osgeo.org
Sat May 26 23:44:09 EDT 2007
   Reporter:  mloskot        |       Owner:  gregboone
       Type:  defect         |      Status:  new
   Priority:  minor          |   Milestone:
  Component:  Documentation  |     Version:
   Severity:  3              |    Keywords:  DevGuide
External_id:                 |
 In the FDO Developer’s Guide (June 2006), on page 84 there is sample
 presenting how to use ApplySchema command to ''Creating a Feature
 Schema''.
 As 3rd code ''instruction'' there is
 // Create the ApplySchema command
 // Create the feature schema
 // get a pointer to the feature schema's class collection
 // this object is used to add classes to the schema
 GisPtr<FdoClassCollection> sampleClassCollection;
 sampleClassCollection = sampleFeatureSchema->GetClasses();
 and as 6th ''instruction'' the same code is presented:
 // create a feature class, i.e.,
 // get a pointer to the feature class's property collection
Ticket URL: <http://trac.osgeo.org/fdo/ticket/75>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
