[fdo-trac] #168: Use Unicode character types in Oracle and SqlServer providers.
FDO trac_fdo at osgeo.org
Wed Nov 7 13:44:28 EST 2007
 Reporter:  brentrobinson  |         Owner:  brentrobinson
     Type:  enhancement    |        Status:  closed
 Priority:  major          |     Milestone:  3.3.0
Component:  FDO API        |       Version:  3.3.0
 Severity:  3              |    Resolution:  fixed
 Keywords:  nls            |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Revision: 3543
 Author: brentrobinson
 Date: 1:42:39 PM, Wednesday, November 07, 2007
 Message:
 Ticket#168: Create string columns in Oracle and SqlServer datatores as
 nvarchar(2).
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/schema_rb_nnyn_master.txt
 Modified : /trunk/Providers/GenericRdbms/com/fdo_sys.sql
Ticket URL: <http://trac.osgeo.org/fdo/ticket/168#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
