[fdo-trac] #188: OGR and PostGIS providers not working under MapGuide on Ubuntu 7.10
FDO trac_fdo at osgeo.org
Fri Nov 30 17:44:28 EST 2007
   Reporter:  jbirch        |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.3.0
  Component:  Build System  |     Version:  3.3.0
   Severity:  3             |    Keywords:
External_id:                |
 From Jo Cook on the mapguide-users mailing list:
 I have managed to build MGOS2 on Ubuntu 7.04 with help from Jason's great
 instructions on the wiki. However, when I try and make a new data
 connection with either postgis or ogr I get errors.
 In mapguide studio when I try to make a postgis connection I get the
 default feature editor screen and errors in my error log saying
 CLNT_8_UNABLE_TO_LOAD_LIBRARY.
 When I make an ogr connection I get the proper editor (with data source
 and readonly connection options) but I get a connection failed error when
 I try and test the connection. The error log says
 CLNT_4_PROVIDERNOTREGISTERED.
 I have tested my connection string with ogrinfo and it works, and I have
 checked that both providers are in my providers.xml file.
 I have also tested both connection strings with testconnection in the web
 tier test suite and both give me the CLNT_4_PROVIDERNOTREGISTERED error.
 Has anyone successfully managed to use either of these connectors with
 Ubuntu, and how do I begin debugging the problem?
 Many thanks
 Jo
Ticket URL: <http://trac.osgeo.org/fdo/ticket/188>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
