[fdo-trac] #127: SDF and SHP create scrollable readers with select list and sort on computed identifiers
FDO trac_fdo at osgeo.org
Tue Oct 2 13:15:07 EDT 2007
identifiers
   Reporter:  badreddinekaroui  |       Owner:  gregboone
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.3.0
  Component:  SDF Provider      |     Version:  3.2.0
   Severity:  3                 |    Keywords:
External_id:                    |
 The SDF and SHP scrollable reader do not work if a select list is used
 with the select command. Also if the computed identifier is used for
 sorting, then both providers throw exceptions.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/127>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
