[fdo-trac] #147: DescribeSchema slow for config files and datastore with foreign keys and views.
FDO trac_fdo at osgeo.org
Thu Oct 25 15:49:02 EDT 2007
views.
 Reporter:  brentrobinson                      |         Owner:  brentrobinson
     Type:  defect                             |        Status:  assigned
 Priority:  major                              |     Milestone:  3.3.0
Component:  FDO API                            |       Version:  3.3.0
 Severity:  2                                  |    Resolution:
 Keywords:  config performance DescribeSchema  |   External_id:
Comment (by brentrobinson):
 Revision: 3487
 Author: brentrobinson
 Date: 11:24:43 AM, Thursday, October 25, 2007
 Message:
 Ticket#147: Avoid foreign key queries for association properties loaded
 from config doc. Allow bulk loading of view dependencies when FDO
 connection uses config doc.
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Lp/SchemaElement.h
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Owner.h
 Modified :
 /trunk/Utilities/SchemaMgr/Src/Sm/Lp/AssociationPropertyDefinition.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/147#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
