[fdo-trac] #117: PostGIS provider does not display attribute names in MapGuide when no PK present
FDO trac_fdo at osgeo.org
Tue Sep 11 03:34:26 EDT 2007
present
   Reporter:  jbirch            |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.3.0
  Component:  PostGIS Provider  |     Version:  3.2.2
   Severity:  3                 |    Keywords:
External_id:                    |
 Not sure if this is a defect, or expected behaviour from FDO providers.
 Anyway, if a table is added which does not contain a primary key, you can
 display it in the map, but the column names/values are not available for
 display as properties.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/117>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
