[fdo-trac] #121: PostGIS extents calculations do not appear to be working
FDO trac_fdo at osgeo.org
Tue Sep 11 18:00:01 EDT 2007
 Reporter:  jbirch            |         Owner:  mloskot
     Type:  defect            |        Status:  new
 Priority:  major             |     Milestone:  3.3.0
Component:  PostGIS Provider  |       Version:  3.2.2
 Severity:  3                 |    Resolution:
 Keywords:                    |   External_id:
Old description:
> I'm not sure if this is a PostGIS Provider bug, or a MapGuide problem,
> but I'll start here.
> When I load a set of tables that have a relatively small extent on a
> local arbitrary scale (somewhere around -100, -100, 100, 100, you can get
> the actual extents from the provider log) the layer will can be created
> and visualized in the !MapGuide Studio layer preview screen just fine.
> However, when adding one of these layers to a new Map definition, the
> data extents of the map are not updated correctly to reflect the extents
> of the layer, and need to be set manually.
New description:
 I'm not sure if this is a PostGIS Provider bug, or a !MapGuide problem,
 When I load a set of tables that have a relatively small extent on a local
 arbitrary scale (somewhere around -100, -100, 100, 100, you can get the
 actual extents from the provider log) the layer will can be created and
 However, when adding one of these layers to a new Map definition, the data
 extents of the map are not updated correctly to reflect the extents of the
Ticket URL: <http://trac.osgeo.org/fdo/ticket/121#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
