[fdo-trac] #297: OGR connection string shouldn't have trailing slash
FDO trac_fdo at osgeo.org
Fri Apr 4 08:40:22 EDT 2008
   Reporter:  traianstanev  |       Owner:  traianstanev
       Type:  defect        |      Status:  new
   Priority:  minor         |   Milestone:
  Component:  OGR Provider  |     Version:  3.3.0
   Severity:  3             |    Keywords:
External_id:                |
 Here is the description from Kenneth:
 I have built an editor for the OGR provider in my MapStudio OS project.
 I noticed that the OGR provider does not accept the %MG_DATA_FILE_PATH%
 parameter but does accept another path.
 After digging around, I found out that OGR rejects directories as
 datasources, if they have a trailing slash.
 This prevents using the entire repository storage as a datasource, so I
 made a small patch that removes a trailing slash, if any.
 There should be no compatibility issuses, as none of the other types of
 connectionstrings are likely to end with a backslash.
 Regards, Kenneth, GEOGRAF A/S
Ticket URL: <http://trac.osgeo.org/fdo/ticket/297>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
