[fdo-trac] #302: SHP Japanese field names turns into english names when apply schema
FDO trac_fdo at osgeo.org
Thu Apr 10 11:08:50 EDT 2008
 Reporter:  romicadascalescu  |         Owner:  gregboone
     Type:  defect            |        Status:  closed
 Priority:  major             |     Milestone:  3.4.0
Component:  SHP Provider      |       Version:  3.3.1
 Severity:  3                 |    Resolution:  fixed
 Keywords:                    |   External_id:
Changes (by romicadascalescu):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed function which generate the property names, checking for invalid
 characters and checking the size of the property (in case the property is
 too
 long the method cuts the property name to fit in maximum 11 bytes).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/302#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
