[fdo-trac] #304: SQLServer Spatial: validate the geometries
FDO trac_fdo at osgeo.org
Thu Apr 10 13:54:09 EDT 2008
   Reporter:  danstoica          |       Owner:  danstoica
       Type:  enhancement        |      Status:  new
   Priority:  major              |   Milestone:
  Component:  SQLServer Spatial  |     Version:  3.3.0
   Severity:  3                  |    Keywords:
External_id:                     |
 Apparently SqlServer2008 doesn't support invalid geometries with spatial
 filters. The fact one can select invalid geometries but cannot query a
 table containg such geometries sounds to me as an inconsistency at least.
 Since Microsoft seems reluctant to address this issue, an workaround is
 necessary:
 1) filter out the invalid geometries. That is, use "STIsValid() AND
 ST<spatial op>".
 This is skip the invalid geometries.
 2) implement IsValid() custom function. The user can use it in order to
 find out which geometries are invalid and potentialy will be skipped by
 the spatial queries.
 Syntax:
 IsValid(<geometry_property>) with a FdoInt32 return result type.
 For example, to find out the invalid geometries:
 Select * from <class> where IsValid(<property>) = 0;
Ticket URL: <http://trac.osgeo.org/fdo/ticket/304>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
