[fdo-trac] #314: PostGIS provider : check-out/check-in crashes Autodesk Map
FDO trac_fdo at osgeo.org
Thu Apr 17 09:00:42 EDT 2008
   Reporter:  bscott            |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  blocker           |   Milestone:  3.4.0
  Component:  PostGIS Provider  |     Version:  3.2.0
   Severity:  1                 |    Keywords:
External_id:                    |
 As soon as we hit the check-out or the check-in features command it
 crashes Autodesk Map 2008 ( this append also with Map 2009 )
 I found that if we turn off the transaction capability
 It works ok.
 I will use that approach for the moment
 but i think we will have to check the Transaction support to see what's
 going on.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/314>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
