[fdo-trac] #316: SQLite: Theme function in Studio (2008) is broken
FDO trac_fdo at osgeo.org
Sat Apr 19 00:51:35 EDT 2008
 Reporter:  jbirch           |         Owner:  traianstanev
     Type:  defect           |        Status:  new
 Priority:  major            |     Milestone:
Component:  SQLite Provider  |       Version:  3.3.1
 Severity:  3                |    Resolution:
 Keywords:                   |   External_id:
Comment (by traianstanev):
 Unique() is actually computed by MapGuide itself -- it simply lists all
 the values for the column from the provider and then does its own unique.
 So it is getting some garbage strings from the provider using a regular
 select -- which should in theory work. So it's a bug with regular select.
 I wonder if it has to do with null strings -- if I can't reproduce it with
 my data, I'll ask you to share yours.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/316#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
