[fdo-trac] #318: [REVIEW] PostGIS provider patch 3.4 from Bruno Scott
FDO trac_fdo at osgeo.org
Sat Apr 19 04:49:36 EDT 2008
   Reporter:  mloskot           |       Owner:  mloskot
       Type:  task              |      Status:  new
   Priority:  critical          |   Milestone:  3.4.0
  Component:  PostGIS Provider  |     Version:
   Severity:  3                 |    Keywords:  postgis patch
External_id:                    |
 This task is about reviewing Bruno Scott's big patch for the PostGIS
 provider posted to the list - [http://lists.osgeo.org/pipermail/fdo-
 internals/2008-April/001965.html PATCH : PostGIS provider patch 3.4]
 Here is list of tickets fixed by this patch:
  #94  Generate extent for features assigned to default spatial context
  #106 PostGIS provider cannot delete a feature class
  #171 Fdo Postgis Autogenated identity property is mandatory
  #178 PostGIS : Can't insert in a non-feature class
  #232 Fdo Postgis null and not null filter does not work
  #233 Fdo Postgis in and not in filter does not work
  #234 Fdo Postgis currently does not support anything but lowercase
 identifiers
  #235 Fdo Postgis Exception with insert
  #236 Fdo Postgis does not support non spatial classes
  #241 Implement Support for SelectAggregates, SpatialExtents and Count
  #310 PostGIS provider : change class naming convention without ~
  #311 PostGIS provider : mismatch between FdoGeometricTypes and
 FdoGeometryType
  #312 PostGIS provider : remove boost_date_time dll dependency
  #313 PostGIS provider : can't filter,insert or update date/datetime
  #314 PostGIS provider : check-out/check-in crashes Autodesk Map
 ''mloskot'': Big thanks to Bruno for this patch!
Ticket URL: <http://trac.osgeo.org/fdo/ticket/318>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
