[fdo-trac] #318: [REVIEW] PostGIS provider patch 3.4 from Bruno Scott
FDO trac_fdo at osgeo.org
Sat Apr 19 06:56:09 EDT 2008
 Reporter:  mloskot           |         Owner:  mloskot
     Type:  task              |        Status:  assigned
 Priority:  critical          |     Milestone:  3.4.0
Component:  PostGIS Provider  |       Version:
 Severity:  1                 |    Resolution:
 Keywords:  postgis patch     |   External_id:
Comment (by mloskot):
 Bruno, do you mind if I'd suggest to remove comments about ticket number,
 what was fixed, etc. after the patch is applied?
 For example, here the first line seems redundant to me (after the patch is
 applied to the FDO tree):
 /// ticket #310 - class naming convention wihout ~ - eric barby
 /// Set schema name (physical schame of postgres).
 FDOPOSTGIS_API void SetSchemaName(FdoString* value);
Ticket URL: <http://trac.osgeo.org/fdo/ticket/318#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
