[fdo-trac] #319: SQLite: Problematic conversion
FDO trac_fdo at osgeo.org
Sun Apr 20 02:38:58 EDT 2008
   Reporter:  jbirch           |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:
  Component:  SQLite Provider  |     Version:  3.3.1
   Severity:  3                |    Keywords:
External_id:                   |
 I was trying to pull out a subset of data for testing with #316 using FME,
 and managed to create an SDF that breaks either the convertor (using
 "optimize") or causes an exception in SQLite provider itself if I convert
 the data source without optimizing.
 This file works fine in its native SDF format, and the data converts and
 works fine as the Easement feature class from the !NanaimoCadastre SDF
 (linked to #316).  Something in the FME data transfer process caused it to
 no longer be acceptable to the SQLite provider; perhaps an attribute data
 type changed?
 http://www.jasonbirch.com/temp/NanEase.zip
Ticket URL: <https://trac.osgeo.org/fdo/ticket/319>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
