[fdo-trac] #171: Fdo Postgis Autogenated identity property is mandatory
FDO trac_fdo at osgeo.org
Sun Apr 20 04:30:59 EDT 2008
 Reporter:  bscott            |         Owner:  mloskot
     Type:  defect            |        Status:  new
 Priority:  major             |     Milestone:  3.4.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  3                 |    Resolution:
 Keywords:                    |   External_id:
Old description:
> With FDO it is possible to create a column with Primary = true and
> autogenerate = false.
> I think the PostGis provider should not do that assumption and let the
> user
> manage the primary key if the autogenerate flag is set to false.
> Actually it is mandatory
> there is the piece of code where you can find the limitation:
> void SchemaDescription::DescribeSchema(Connection* conn, FdoString*
> schemaName)
>         ////////////////// SET AUTO-GENERATED TO SINGLE COLUMN PK OF
>  INTEGRAL TYPE //////////////////
> // TODO: It is possible, that user connects to a datastore that was not
> created
> // with FDO, using ApplySchema command, so single column PRIMARY  KEY
> // of integral type, may not have associated sequence named according
> scheme:
> // <tablename>_<columnname>_seq
> // The PostGIS provider uses such scheme to bind a sequence to PK column.
> // TODO: In future, it would be a good idea to automatically
> // replace PK of integral type with serial data type, in ApplySchema
> command.
>      FdoPtr<FdoDataPropertyDefinitionCollection> propsIdentity;
>      propsIdentity = featClass->GetIdentityProperties();
>      if (1 == propsIdentity->GetCount())
>        FdoPtr<FdoDataPropertyDefinition> propId =
> propsIdentity->GetItem(0);
>        assert(NULL != propId);
>        if (FdoDataType_Int16 == propId->GetDataType()
>         || FdoDataType_Int32 == propId->GetDataType()
>         || FdoDataType_Int64 == propId->GetDataType())
>          propId->SetIsAutoGenerated(true);
New description:
 I think the !PostGis provider should not do that assumption and let the
 user
 schemaName)
 created
 scheme:
 command.
Comment (by jbirch):
 Just fixing up the ticket description...
Ticket URL: <http://trac.osgeo.org/fdo/ticket/171#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
