[fdo-trac] #178: PostGIS : Can't insert in a non-feature class
FDO trac_fdo at osgeo.org
Mon Apr 21 13:44:26 EDT 2008
 Reporter:  bscott            |         Owner:  mloskot
     Type:  defect            |        Status:  assigned
 Priority:  blocker           |     Milestone:  3.4.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  1                 |    Resolution:
 Keywords:                    |   External_id:
Changes (by mloskot):
  * status:  new => assigned
Old description:
> In the PostGis provider it is not possible to insert in a non-feature
> class .
> The provider search first for the classdefinition in the "schemaDesc"
> And the schemadesc is only filled with the values from the postgis
> geometry_columns table.
> Here is the piece of code that make that call failed:
> FdoIFeatureReader* InsertCommand::Execute()
>     FdoPtr<FdoClassDefinition>
> classDef(schemaDesc->FindClassDefinition(mClassIdentifier));
>     if (!classDef)
>       throw FdoCommandException::Create(L"[PostGIS] InsertCommand can not
> find class definition");
> Orest Halustchak wrote:
> FdoIInsert is supposed to work on non-feature classes as well. There is
> no separate insert command for these.
New description:
 class .
     if (!classDef)
 FdoIInsert is supposed to work on non-feature classes as well. There is no
Ticket URL: <http://trac.osgeo.org/fdo/ticket/178#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
