[fdo-trac] #332: SQLite: Please provide "Default" Spatial Context when no CS present
FDO trac_fdo at osgeo.org
Wed Apr 23 21:24:32 EDT 2008
 Reporter:  jbirch           |         Owner:  traianstanev
     Type:  enhancement      |        Status:  new
 Priority:  minor            |     Milestone:
Component:  SQLite Provider  |       Version:  3.3.1
 Severity:  3                |    Resolution:
 Keywords:                   |   External_id:
Old description:
> Currently in SQLite, if there is no CS defined for a table, MapGuide is
> not provided with the data extents for that table.
> It would make it easier to work with non-CS data in !MapGuide if the
> provider presented a "Default" !SpatialContext when no CS is defined,
> something like the SHP provider (as described by Bruce):
> <?xml version="1.0" encoding="UTF-8"?>
> <FdoSpatialContextList>
>   <ProviderName>OSGeo.SHP.3.3</ProviderName>
>   <SpatialContext IsActive="true">
>     <Name>Default</Name>
>     <Description></Description>
>     <CoordinateSystemName></CoordinateSystemName>
>     <CoordinateSystemWkt></CoordinateSystemWkt>
>     <ExtentType>Dynamic</ExtentType>
>     <Extent>
>       <LowerLeftCoordinate>
>         <X>-141.00300598144531</X>
>         <Y>41.913318634033203</Y>
>       </LowerLeftCoordinate>
>       <UpperRightCoordinate>
>         <X>-52.620281219482422</X>
>         <Y>83.108322143554688</Y>
>       </UpperRightCoordinate>
>     </Extent>
>     <XYTolerance>0.001000</XYTolerance>
>     <ZTolerance>0.001000</ZTolerance>
>   </SpatialContext>
> </FdoSpatialContextList>
New description:
 Currently in SQLite, if there is no CS defined for a table, !MapGuide is
     <Extent>
     </Extent>
   </SpatialContext>
Comment (by jbirch):
 If I ruled the world, !MapGuide wouldn't be in camel case!
Ticket URL: <https://trac.osgeo.org/fdo/ticket/332#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
