[fdo-trac] #365: [SHP Provider]: When executing IApplySchema, Int32 properties are converted to Decimal properties
FDO trac_fdo at osgeo.org
Fri Aug 1 09:30:36 EDT 2008
   Reporter:  jng           |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:
  Component:  SHP Provider  |     Version:  3.3.1
   Severity:  3             |    Keywords:
External_id:                |
 If you execute an IApplySchema on a SHP connection. Any Int32 properties
 in any class definitions inside the schema (to be applied) will be
 converted to Decimal properties once the schema has been applied.
 This does not happen if the Int32 property happens to be an Identity
 property
Ticket URL: <http://trac.osgeo.org/fdo/ticket/365>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
