[fdo-trac] #288: Remove reliance on FeatId system property
FDO trac_fdo at osgeo.org
Thu Aug 7 11:31:29 EDT 2008
 Reporter:  brentrobinson   |         Owner:  brentrobinson
     Type:  enhancement     |        Status:  closed
 Priority:  major           |     Milestone:  3.4.0
Component:  MySQL Provider  |       Version:
 Severity:  3               |    Resolution:  fixed
 Keywords:                  |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Revision: 4035
 Author: brentrobinson
 Date: 3:18:11 PM, Wednesday, August 06, 2008
 Message:
 Ticket#288: Removed the creation of the FeatId system property in new
 datastores.
 Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Owner.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/Owner.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_no_meta_test1_master.xml
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign3_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_def1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SQLServerSpatial_master.txt
 Modified : /trunk/Providers/GenericRdbms/Src/UnitTest/impexp2a_master.txt
 Modified : /trunk/Providers/GenericRdbms/Src/UnitTest/impexp2b_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/schema_rb_nnyn_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/spatial_context_test1m_master.xml
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/spatial_context_test2m_master.xml
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/spatial_context_test3m_master.xml
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp
 Revision: 4036
 Date: 11:21:33 AM, Thursday, August 07, 2008
 Message:
 Ticket#288: Bumped up FDO MetaSchema version since FeatId system property
 was removed.
 Modified : /trunk/Providers/GenericRdbms/Nls/fdordbmsmsg.mc
 Modified : /trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Owner.cpp
 Modified : /trunk/Providers/GenericRdbms/com/fdo_sys.sql
Ticket URL: <http://trac.osgeo.org/fdo/ticket/288#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
