[fdo-trac] #260: build_* batch files may have incorrect line endings
FDO trac_fdo at osgeo.org
Tue Aug 19 09:09:29 EDT 2008
 Reporter:  jng           |         Owner:  gregboone
     Type:  defect        |        Status:  reopened
 Priority:  major         |     Milestone:  3.3.0
Component:  Build System  |       Version:  3.3.0
 Severity:  3             |    Resolution:
 Keywords:                |   External_id:
Changes (by jng):
  * status:  closed => reopened
  * resolution:  worksforme =>
  * summary:  build_thirdparty.bat fails when specifying install action =>
              endings
Comment:
 I get the same error from the 3.3.1 release source tarball. But looking at
 this problem again in more detail, the issue can be caused by incorrect
 line endings in the batch files.
 I modified all the batch files in the source tarball to make sure they are
 using CRLF line endings and the batch files now work when specifiying
 parameters.
 The batch files need to be checked for correct line endings.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/260#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
