[fdo-trac] #383: SDF: Optimize "in" conditions in select filters.
FDO trac_fdo at osgeo.org
Fri Aug 22 14:28:27 EDT 2008
 Reporter:  brentrobinson                     |         Owner:  brentrobinson
     Type:  enhancement                       |        Status:  closed
 Priority:  major                             |     Milestone:
Component:  SDF Provider                      |       Version:  3.3.1
 Severity:  2                                 |    Resolution:  fixed
 Keywords:  SDF in filter performance select  |   External_id:
Comment (by brentrobinson):
 Performance tested using sdf file containing 785,000 features.
 For the following filter:
         PK1 in ( 200000.0 )
 the before and after times were as follows.
                         Time (sec)
         Disk Caching       Before                  After
         No                 8.687                   0.016
         Yes                0.844                   < 0.001
 Disk Caching = No was when the SDF file had not yet been put into the disk
 cache, at the start of the test.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/383#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
